手掌关键点检测
手掌关键点指的是5个手指的关节位置,通过对关键点分析可以判断任意手势应用。
检测摄像头拍摄到的画面中的手掌关键点并画图指示。
手掌关键点检测模型已经预先训练好,存放在代码同一目录下,我们只需要加载模型文件,使用kpu库进行推理,并将返回的结果画图并显示即可。
实验名称:手掌关键点检测
import cv2, time, os
if os.path.exists("./hand_det.kmodel") and os.path.exists("./handkp_det.kmodel"):
hand_det_path = "./hand_det.kmodel"
hand_kp_path = "./handkp_det.kmodel"
elif os.path.exists("/data/app/hand-keypoint/hand_det.kmodel") and \
os.path.exists("/data/app/hand-keypoint/handkp_det.kmodel"):
hand_det_path = "/data/app/hand-keypoint/hand_det.kmodel"
hand_kp_path = "/data/app/hand-keypoint/handkp_det.kmodel"
detector = kpu.HAND_KEYPOINT(hand_det_kmodel=hand_det_path,
hand_kp_kmodel=hand_kp_path)
ft = cv2.freetype.createFreeType2()
ft.loadFontData("/usr/share/fonts/truetype/wqy/wqy-zenhei.ttc", 0)
global ft
thickness=-1,
line_type=cv2.LINE_AA,
bottomLeftOrigin=True
lcd_dir = direction.get_lcd()
if lcd_dir == 2:
frame_count = 0
# 手部骨架连接(5 根手指)
HAND_CONNECTIONS = [
(0, 1), (1, 2), (2, 3), (3, 4), # 拇指
(0, 5), (5, 6), (6, 7), (7, 8), # 食指
(0, 9), (9, 10), (10, 11), (11, 12), # 中指
(0, 13), (13, 14), (14, 15), (15, 16),# 无名指
(0, 17), (17, 18), (18, 19), (19, 20),# 小指
FINGER_COLORS = [
(255, 0, 0), # 拇指 - 蓝
(0, 255, 0), # 食指 - 绿
(255, 255, 0), # 中指 - 青
(0, 255, 255), # 无名指 - 黄
(255, 0, 255), # 小指 - 紫
# 摄像头读取一帧
# 手掌关键点检测
results = detector.run(img, 0.2, 0.5)
# 输出检测结果
for result in results:
print(f"HAND_KEYPOINT rel={result.reliability:.3f} "
f"box=({result.x},{result.y},{result.w},{result.h}) "
f"kps={len(result.keypoints)}")
# 绘制结果
color = (255, 0, 255)
label_text = f"hand {result.reliability:.2f}"
left_x = int(result.x)
left_y = int(result.y)
right_x = int(result.x + result.w)
right_y = int(result.y + result.h)
# 获取文字尺寸
(label_width, label_height), baseline = ft.getTextSize(label_text, 30, -1)
# 防止标签超出图像顶部
text_y = left_y - baseline - 5
if bg_y1 < 0:
bg_y1 = 0
text_y = label_height + 5
# 画检测框
putText_Chinese(img, label_text, (left_x + 5, text_y), fontScale=30, color=color)
# 绘制关键点
kps = result.keypoints
for i, kp in enumerate(kps):
cv2.circle(img, (kp.x, kp.y), 3, (0, 255, 0), -1)
# 绘制手指连线
if len(kps) >= 21:
for idx, (start, end) in enumerate(HAND_CONNECTIONS):
finger_idx = idx // 4
color = FINGER_COLORS[finger_idx] if finger_idx < 5 else (128, 128, 128)
cv2.line(img,
(kps[start].x, kps[start].y),
(kps[end].x, kps[end].y),
color, 2)
frame_count = 0
start_time = current_time
print(f"FPS: {fps:.1f}")
#FPS显示
#putText_Chinese(img, f'FPS: {fps:.1f}', (500, 30), fontScale=30, color=(0, 255, 0))
# 显示图像
运行代码,将摄像头正对下图手掌。
hand_detection
hand_detection
