人手检测
人手检测是判断摄像头画面中有无出现人的手部。本节我们来学习一下如何通过MicroPython编程快速实现人手检测。
人手检测并通过画框提示。
本实验还是使用到YOLO2网络,结合人手检测模型来识别人手。KPU对象说明可参考KPU简介章节内容。
#实验名称:人手检测
#翻译和注释:01Studio
sensor.reset() # Reset and initialize the sensor. It will
# run automatically, call sensor.run(0) to stop
sensor.set_pixformat(sensor.RGB565) # Set pixel format to RGB565 (or GRAYSCALE)
sensor.set_framesize(sensor.QVGA) # Set frame size to QVGA (320x240)
sensor.set_vflip(True) #摄像头后置
sensor.skip_frames(time = 1000) # Wait for settings take effect.
clock = time.clock() # Create a clock object to track the FPS.
od_img = image.Image(size=(320,256))
anchor = (0.8125, 0.4556, 1.1328, 1.2667, 1.8594, 1.4889, 1.4844, 2.2000, 2.6484, 2.9333)
#加载KPU模型,放在SD卡根目录
kpu.load_kmodel("/sd/hand_detect.kmodel")
#需要将kmdel通过固件下载工具下载到0x300000的位置(3M偏移)
#kpu.load_kmodel(0x300000, 1438888)
kpu.init_yolo2(anchor, anchor_num=5, img_w=320, img_h=240, net_w=320 , net_h=256 ,layer_w=10 ,layer_h=8,
threshold=0.7, nms_value=0.3, classes=1)
a = od_img.draw_image(img, 0,0)
od_img.pix_to_ai()
#将摄像头采集图片输送到KPU和yolo模型运算。
kpu.run_with_output(od_img)
dect = kpu.regionlayer_yolo2()
fps = clock.fps()
if len(dect) > 0: #识别到人手
print("dect:",dect)
for l in dect :#画矩形
a = img.draw_rectangle(l[0],l[1],l[2],l[3], color=(0, 255, 0))
a = img.draw_string(0, 0, "%2.1ffps" %(fps), color=(0, 60, 128), scale=2.0)
kpu.deinit()
将示例程序中的hand_detect.kmodel模型文件拷贝到SD卡中。
在CanMV IDE中运行上述代码,将摄像头对准手部,可以看到被正确的识别出来:
hand_recognition
hand_recognition
