头部检测
头部检测是判断摄像头画面中有无出现人体头部,本节我们来学习一下如何通过MicroPython编程快速实现头部检测。
人体头部检测并通过画框提示。
本实验还是使用到YOLO2网络,结合人体检测模型来识别头部。KPU对象说明可参考KPU简介章节内容。
#实验名称:头部检测
#实验平台:01Studio CanMV K210
sensor.reset() # Reset and initialize the sensor. It will
# run automatically, call sensor.run(0) to stop
sensor.set_vflip(1) #将摄像头设置成后置方式(所见即所得)
sensor.set_hmirror(1) #GC0328摄像头(如果使用ov2640摄像头,注释此行。)
sensor.set_pixformat(sensor.RGB565) # Set pixel format to RGB565 (or GRAYSCALE)
sensor.set_framesize(sensor.QVGA) # Set frame size to QVGA (320x240)
sensor.skip_frames(time = 1000) # Wait for settings take effect.
clock = time.clock() # Create a clock object to track the FPS.
od_img = image.Image(size=(320,256))
anchor_head_detect = (0.1074, 0.1458, 0.1367, 0.2137, 0.1758, 0.2824, 0.2441, 0.3333, 0.2188,
0.4167, 0.2969, 0.5000, 0.4102, 0.6667, 0.6094, 0.9722, 1.2364, 1.6915)
head_kpu = KPU()
#加载KPU模型,放在SD卡根目录
head_kpu.load_kmodel("/sd/uint8_head_detect_v1_old.kmodel")
head_kpu.init_yolo2(anchor_head_detect, anchor_num=9, img_w=320, img_h=240, net_w=320 ,
net_h=256 ,layer_w=10 ,layer_h=8, threshold=0.7, nms_value=0.2, classes=1)
a = od_img.draw_image(img, 0,0)
od_img.pix_to_ai()
#将摄像头采集图片输送到KPU和yolo模型运算。
head_kpu.run_with_output(od_img)
head_boxes = head_kpu.regionlayer_yolo2()
if len(head_boxes) > 0:#识别到人体头部
print(head_boxes) #打印所有头部识别框信息
for l in head_boxes : #画矩形
a = img.draw_rectangle(l[0],l[1],l[2],l[3], color=(255, 0, 0),thickness=2)
fps = clock.fps()#计算FPS
a = img.draw_string(0, 0, "%2.1ffps" %(fps), color=(0, 60, 128), scale=2.0)
head_kpu.deinit()
将资料包例程源码中的 uint8_head_detect_v1_old.kmodel 模型文件拷贝到SD卡中。
在CanMV IDE中运行上述代码,将摄像头对准下方图片,可以看到人体头部被正确的识别出来:
head_detection
head_detection
