车牌识别
车牌识别用于识别车牌内容,支持蓝牌和新能源绿牌。
识别车牌内容通过写字符和画图指示。
车牌识别相关模型已经预先训练好,存放在代码同一目录下,我们只需要加载模型文件,使用kpu库进行推理,并将返回的结果画图并显示即可。
实验名称:车牌识别
import cv2, time, os, colorsys
if os.path.exists("./licence_det.kmodel"):
det_model_path = "./licence_det.kmodel"
elif os.path.exists("/data/app/license-recg/licence_det.kmodel"):
det_model_path = "/data/app/license-recg/licence_det.kmodel"
raise FileNotFoundError("licence_det.kmodel 模型文件缺失,请检查当前路径与系统路径下的模型文件是否存在。")
if os.path.exists("./licence_rec.kmodel"):
rec_model_path = "./licence_rec.kmodel"
elif os.path.exists("/data/app/license-recg/licence_rec.kmodel"):
rec_model_path = "/data/app/license-recg/licence_rec.kmodel"
raise FileNotFoundError("licence_rec.kmodel 模型文件缺失,请检查当前路径与系统路径下的模型文件是否存在。")
if os.path.exists("./anchors_640.bin"):
anchors_bin_path = "./anchors_640.bin"
elif os.path.exists("/data/app/license-recg/anchors_640.bin"):
anchors_bin_path = "/data/app/license-recg/anchors_640.bin"
raise FileNotFoundError("anchors_640.bin 文件缺失,请检查当前路径与系统路径下的模型文件是否存在。")
# 车牌字符字典(74 类)
reco_labels = [
"挂","使","领","澳","港","皖","沪","津","渝","冀","晋","蒙","辽","吉","黑","苏",
"浙","京","闽","赣","鲁","豫","鄂","湘","粤","桂","琼","川","贵","云","藏","陕",
"甘","青","宁","新","警","学",
"0","1","2","3","4","5","6","7","8","9",
"A","B","C","D","E","F","G","H","J","K","L","M","N","P","Q","R","S","T","U","V","W","X","Y","Z",
"_","-",
det_size = 640 #检测模型尺寸
rec_size = (220, 32) #ocr模型尺寸
detector = kpu.LICENCE_DETECT(det_model_path, rec_model_path, anchors_bin_path,
reco_labels, det_size, rec_size) # 加载模型
# 绘制中文
thickness=-1, # 笔画粗细
# 摄像头读取一帧
# 阻塞式目标检测
results = detector.run(img)
FONT_SIZE = 30 # 字体大小
color = (0, 0, 255)
# 输出检测结果
for r in results:
print(f"{r.reliability:.2f}: {r.text} {r.corners}")
# 绘制边框
pts = r.corners
cv2.line(img, pts[0], pts[1], (0, 0, 255), 2)
cv2.line(img, pts[1], pts[2], (0, 0, 255), 2)
cv2.line(img, pts[2], pts[3], (0, 0, 255), 2)
cv2.line(img, pts[3], pts[0], (0, 0, 255), 2)
# 绘制车牌信息
putText_Chinese(img, r.text, (pts[0][0], max(pts[0][1]- 8, 24)), fontScale=FONT_SIZE, color=color)
#FPS显示
putText_Chinese(img, f'FPS: {fps:.1f}', (10, 30), fontScale=30, color=(0, 255, 0))
# 显示图像
运行代码,将摄像头正对下图车牌。
hand_detection
hand_detection
