人体关键点检测
人体关键点检测是指标注出人体关节等关键信息,分析人体姿态、运动轨迹、动作角度等。
检测摄像头拍摄到的画面中的人体关键点并通过画图提示。
人体关键点检测模型已经预先训练好,存放在代码同一目录下,我们只需要加载模型文件,使用kpu库进行推理,并将返回的结果画图并显示即可。
实验名称:人体关键点检测
说明:检测人体并描绘关键点
import cv2, time, os
if os.path.exists("./yolov8n-pose.kmodel"):
model_path = "./yolov8n-pose.kmodel"
elif os.path.exists("/data/app/person-keypoint/yolov8n-pose.kmodel"):
model_path = "/data/app/person-keypoint/yolov8n-pose.kmodel"
model_size = 320 #模型尺寸
detector = kpu.PERSON_KEYPOINT(model_path, model_size) # 加载模型
# 绘制中文
thickness=-1, # 笔画粗细
# 摄像头读取一帧
# 阻塞式目标检测
boxes = detector.run(img, 0.5, 0.45)
# 输出检测结果
for box in boxes:
print(
"{:f} ({:4d},{:4d}) w{:4d} h{:4d}".format(
box.reliability,
box.x,
box.y,
box.w,
box.h,
# 绘制检测框和中文标签
for box in boxes:
FONT_SIZE = 30 # 字体大小
color = (0, 255, 0)
label_text = f"person {box.reliability:.2f}"
left_x = int(box.x)
left_y = int(box.y)
right_x = int(box.x + box.w)
right_y = int(box.y + box.h)
# 获取文字尺寸
# 防止标签超出图像顶部
text_y = left_y - baseline -5
if bg_y1 < 0:
bg_y1 = 0
text_y = label_height + 5
# 画检测框
#输出字符
putText_Chinese(img, label_text, (box.x + 5, box.y), fontScale=FONT_SIZE, color=color)
# 绘制骨架连线(带颜色)
SKELETON = [
(15, 13), (13, 11), (16, 14), (14, 12), (11, 12),
(5, 11), (6, 12), (5, 6),
(5, 7), (6, 8), (7, 9), (8, 10),
(1, 2), (0, 1), (0, 2), (1, 3), (2, 4),
(3, 5), (4, 6),
for limb_idx, (a, b) in enumerate(SKELETON):
kp_a = box.keypoints[a]
kp_b = box.keypoints[b]
if kp_a.confidence > 0.5 and kp_b.confidence > 0.5:
color = detector.LIMB_COLORS[limb_idx]
cv2.line(img, (kp_a.x, kp_a.y), (kp_b.x, kp_b.y),
color, 2)
# 绘制 17 个关键点(不同颜色)
for k, kp in enumerate(box.keypoints):
if kp.confidence > 0.5:
color = detector.KPS_COLORS[k]
cv2.circle(img, (kp.x, kp.y), 4, color, -1)
#FPS显示
#putText_Chinese(img, f'FPS: {fps:.1f}', (10, 30), fontScale=30, color=(0, 255, 0))
# 显示图像
运行代码,将摄像头正对下方人体图进行关键点检测。
原图1:
person_keypoint
识别结果1:
person_keypoint
原图2:
person_keypoint
识别结果2:
person_keypoint
