口罩识别
识别人脸是否戴口罩。
识别人脸是否有配戴口罩并通过写字符和画图指示。
口罩识别相关模型已经预先训练好,存放在代码同一目录下,我们只需要加载模型文件,使用kpu库进行推理,并将返回的结果画图并显示即可。
实验名称:口罩识别
import cv2, time, os
from walnutpi import Display,Sensor,kpu,IDE,direction
if os.path.exists("./face_detection_320.kmodel") and os.path.exists("./prior_data_320.bin") and os.path.exists("./face_mask.kmodel"):
det_model_path = "./face_detection_320.kmodel"
mask_model_path = "./face_mask.kmodel"
anchors_path = "./prior_data_320.bin"
elif os.path.exists("/data/app/mask-det/face_detection_320.kmodel") and os.path.exists("/data/app/mask-det/prior_data_320.bin") and os.path.exists("/data/app/mask-det/face_mask.kmodel"):
det_model_path = "/data/app/mask-det/face_detection_320.kmodel"
anchors_path = "/data/app/mask-det/prior_data_320.bin"
mask_model_path = "/data/app/mask-det/face_mask.kmodel"
model_size = 320 #模型尺寸
detector = kpu.FACE_MASK(det_model_path, anchors_path, model_size, mask_model_path) #加载模型
# 绘制中文
thickness=-1, # 笔画粗细
# 摄像头读取一帧图像
# 执行目标检测,设置置信度阈值为 0.6,IoU 阈值为 0.7
results = detector.run(img, 0.6, 0.7)
# 打印并绘制结果
for result in results:
# 打印结果,当人脸数量过多时会降低识别帧率。
# ========== 人脸框坐标 ==========
print("=" * 40)
print(f"人脸框: 左上角({result.x}, {result.y}) 宽:{result.w} 高:{result.h}")
print(f"置信度: {result.reliability:.3f}")
# ========== 5个关键点坐标 ==========
print(f"左眼 : ({result.left_eye.x:3d}, {result.left_eye.y:3d})")
print(f"右眼 : ({result.right_eye.x:3d}, {result.right_eye.y:3d})")
print(f"鼻子 : ({result.nose.x:3d}, {result.nose.y:3d})")
print(f"左嘴角 : ({result.left_mouth.x:3d}, {result.left_mouth.y:3d})")
print(f"右嘴角 : ({result.right_mouth.x:3d}, {result.right_mouth.y:3d})")
print("=" * 40)
# 将口罩概率大于0.6的视为戴口罩
is_mask = result.mask > 0.6
color = (0, 0, 255)
if is_mask :
color = (0, 255, 0)
# 绘制 人脸识别框
cv2.rectangle(img, (result.x, result.y),
(result.x + result.w, result.y + result.h),
color, 2)
label = f"{result.reliability:.2f}"
if is_mask :
label += "戴口罩"
else :
label += "无"
# 绘制戴口罩的概率
putText_Chinese(img, label, (result.x+5, max(result.y-5, 24)), fontScale=30, color=color)
# 绘制 5 个关键点
cv2.circle(img, (result.left_eye.x, result.left_eye.y), 4, (0, 0, 255), -1) # 左眼
cv2.circle(img, (result.right_eye.x, result.right_eye.y), 4, (0, 255, 255), -1) # 右眼
cv2.circle(img, (result.nose.x, result.nose.y), 4, (255, 0, 255), -1) # 鼻子
cv2.circle(img, (result.left_mouth.x, result.left_mouth.y), 4, (0, 255, 0), -1) # 左嘴角
cv2.circle(img, (result.right_mouth.x, result.right_mouth.y), 4, (255, 0, 0), -1) # 右嘴角
Display.show(img) #显示到屏幕上
IDE.show(img) # 发送到ide窗口内显示
运行代码,将摄像头对准戴口罩人员,可以看到被正确的识别出来,支持多个口罩识别。
  • 戴口罩场景:
hand_detection
hand_detection
  • 未戴口罩场景:
hand_detection
hand_detection
